OK so this is probably the millionth thread on this topic and I'm sure everyone is sick of people asking how to make a PSU.
However! As a chemist I'm rather new to electronics, it simply isn't my forte (yet). So rather than designing one I was thinking more in the lines of replicating an existing design (maybe modify it a bit down the road). It beats giving 200+ euros for a decent factory made power supply!
The power supply would be used mainly for diy electroplating, electrolysis and power supply for work in progress electronics builds. So it doesn't really have to be insanely powerful.
For voltage output I was thinking something like 0 to 30V at most with <0.05 to 3A current. I was thinking of a simple knob operated action with a digital volt/current meter embedded, none of that fancy micro-controller doo-dads, that's a project for another time.
As for the type, I'd go with linear because I'd like a low noise power supply.
Regarding input... I still haven't decided to be honest. It really depends on the type of transformer I can get my hands on. It will probably be single, that's what I'll be going at for the moment.
I've found some schematics online... like this one:
http://www.electronics-lab.com/project/0-30-vdc-stabilized-power-supply-with-current-control-0-002-3-a/ it appears to be perfect for what I need
Q1 = BC548, NPN transistor or BC547
Q2 = 2N2219 NPN transistor
Q3 = BC557, PNP transistor or BC327
Q4 = 2N3055 NPN power transistor
or this one:
http://www.pocketmagic.net/variable-regulated-power-supply/ although it's too powerful for my needs, but I reckon it could be fitted with a less powerful transformer and still do the job (perhaps do it better)
I've also found this:
http://lea.hamradio.si/~s55wt/Napajalnik_30V10A/Navodila%20za%20izdelavo.pdf It's in german, sadly I don't understand german, but I kinda get what it's about. This one is 10A, which would be overkill again. Like with the previous one, I assume yo could just lower the input voltage with a weaker transformer (+ adjust all the high power components) and it would work just fine.
Now I'd like to ask if these schematics are good, if they aren't just some shite put online by people who want others to burn down their houses.
I'd be grateful for any input! If you know of any good schematics or advice, please share them it would help immensely!
