A lesson from Metrology... For voltage dividers, put the variable resistor in parallel with one of the fixed resistors. Calculate the resistor values so that the variable resistor adjustment range is only sufficient to compensate for worst case resistor and other tolerances. That way, if the wiper goes open circuit, nothing dramatic will happen. Always start with two fixed resistors for the divider and provide the minimum adjustment needed.
