I took some measures....
Indeed, my modules have fake chips aboard.
See ripple noise in the following conditions:
- 12 V In
- 5 V Out
- 1A or 2A load (my dummy load is not purely resistive, which could explain why the ripple noise is so high and distorded)
(See screenshots and values attached)
Note that the temperatures were taken without any heatsink or fan, each time after 10-15 min of running
Strangely, the ripple level is higher at 1 A than at 2 A, but for my app, even 300 mV at that frequency is not a problem at all.
The input capacitor heats up also, but I guess this is only due to its proximity to the chip.
I will try to mount a heatsink at the rear of the PCB after having scratched the silkscreen. Thermal vias are already visible .
I have seen that idea in the blog spot of k6jca mentionned by Ian.
With that in place, I bet that I can source 1.5 A without a problem
I will also add and/or replace the output caps to try to lower a bit the ripple.
However, sorry for that, but I still don't understand how I can.....
... injecting current at the ADJ pin will lower the output. With your DAC at its max output, connect a resistor, initially the same value as the pot on the module, between the buffered DAC output (or filtered and buffered PWM output), and decrease its resistance till you get the control range you want.
