Author Topic: Varicap diode #question  (Read 4280 times)
Offline M0BSWTopic starter
  • Left this site 2013, they will not delete it ????
« on: March 23, 2014, 12:18:02 pm »
I have a circuit which states varicap diode its code is 1n4004, I looked it up and it says silicon regulator diode, well that 's not a varicap diode is it. :palm:
no one would or will tell me how to delete this account
Offline electronics man
Re: Varicap diode #question
« Reply #1 on: March 23, 2014, 12:36:09 pm »
do you have a schematic?
follow me on twitter @get_your_byte
« Reply #2 on: March 23, 2014, 12:39:12 pm »
It can be used as a varicap diode, as a varicap diode is a regular diode that is specced to have the quoted values of reverse bias capacitance on the junction. A typical signal diode has low capacitance, 3-4pF, and a power diode has higher.
Typically 8-15pF at 4v according to this datasheet.
http://www.diodes.com/datasheets/ds28002.pdf
If you want higher use a larger power diode, but YMMV. Leakage current as well will be a lot higher. Up to 50uA while a varicap can be a lot lower.
Online edpalmer42
« Reply #3 on: March 23, 2014, 05:10:29 pm »
Check out these pages for info on using regular diodes as varactor (varicap) diodes:
http://www.hanssummers.com/varicap/varicaporig.html
http://www.hanssummers.com/varicap/varicapled.html
Ed
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: March 23, 2014, 11:00:02 pm »
Beware that 1. no one publishes data on the Q factor of junction capacitance, because they don't need to, and 2. probably because they don't want to anyway.  Schottky diodes, for instance, are oft quoted as saving reverse recovery losses; but the capacitance is so large (and probably lossy -- I wish I had numbers), they can actually perform worse in some circuits.
Seven Transistor Labs, LLC
Tac Eht Xilef
  • Guest
« Reply #5 on: March 24, 2014, 01:05:47 am »
About 10~15 years ago I compared the Q factor as varicaps on various power diodes I had lying around. I don't remember the exact diodes I used (certainly 1N400x, as well as others including some weird unmarked ones from my telco days & various stud rectifiers), and I definitely don't remember the exact numbers, but they were surprisingly comparable to typical low capacitance / low CR varicaps. Even more surprisingly, devices of the same type were fairly consistent across batches & manufacturers. I wouldn't use them for front-end tuning, but they were certainly good enough for tuned oscillators and filters at a pinch.
« Last Edit: March 24, 2014, 01:10:08 am by Tac Eht Xilef »
