Author Topic: Battery Power UpGrade Questions  (Read 381 times)
Offline Oscar MersaidTopic starter
« on: June 26, 2020, 08:07:42 pm »
Hello all,
I have a small devise that takes the small 3.7 / 870mAH LiPo Battery in the attached photo.
I would like to up grade this devise to a larger Li-Ion 3000 MaH Bat.
I've been told that the PCB connected to the LiPo Bat is a BMS.
If that is true, would it be possible to use the same BMS on the larger Mah Li Ion Bat, or would I need to figure out a
more proper BMS for the larger bat ?
Much appreciated, Oscar
