A bit of a strange post I grant you but on something I've never run across before. Perhaps I wasn't looking hard enough but Vertically Mounted Resistors recently caught me by surprise. I suppose this could also apply to any component of axial design but in this case it's Resistors.
I've been building a lot of Velleman / WHADDA kits as of late to polish up my soldering skills and am currently working on their EDU09 PC Oscilloscope Kit which has 28 Resistors that require vertical mounting. How prevalent is that in the industry?
I had to construct a lead-bending jig for them to get any kind of uniformity in their mounting and it was a real pain in the arse installing them, unlike their horizontally mounted brethren. I guess when a PCB Layout Designer runs out of room they have to do stuff like this but the PCB looks big enough to me to have had at least SOME of them mounted horizontally. Just kind of mystified why Velleman did this on this kit. The PCB looks like a Petroleum Refinery with all of its Cracking Towers.
Aside from the obvious increase in shorting potential from components folding over or something getting in there, would there be any real chance of all those tall, exposed leads becoming antenna's and adding something weird to the mix?
Barry
Wow that is a lot of vertical for ya, wow. When you run out of real estate the only way to go is up
They used to do that with a lot of stuff especially power resistors that give off a lot of heat. Today though they usually use SMD components so this may be an older design or something or else they just didnt want to use SMD components.
The idea is to save PC board space. It is possible that the extra lead length would cause other effects but if it works then it works and since this technique was used a lot in the past if they tested it that way then it must work.
The way the leads are bent looks a little unusual to me as most of the ones from the past just fold the top lead over and stick both leads into the PC board and solder, no extra bends at the bottom. The extra bends prevent sticking the bottom end lead in too far or mounting it tilted over a little. With a little care when soldering you dont need those extra bends however. When the bottom of the resistor is placed right on top of the board with no lead under the resistor just through the hole, the component has less chance of bending over too but that could put extra strain on the lead. That was the way some of them were done in the past however. That also means there will be high heat very close to the resistor body when soldering may alter the resistance a little, but that's the way they did it back then.
The resistors are mounted unusually high off the board too so maybe they wanted to try to keep them cooler for some reason, maybe they are sized very close to ideal or slightly under so they get warm. You can feel them once you get it assembled.
Another idea that was used was to put Teflon tubing on the long lead to prevent shorting. You can add that if you want too. Another idea is to use silicone rubber made for electronics between parts to keep them from tilting over and hitting another part. That is usually used when there are only a couple parts that need it though, but hey if you are worried then think about that. It had better be silicone rubber made for electronic work though as some of the regular stuff has chemicals that could deteriorate the component leads.
You may also be able to get away with a conformal coating but that can get a little messy and not as good as Teflon tubing.
