Electronics => Beginners => Topic started by: soFPG on May 06, 2018, 12:41:21 pm
Title: VHDL - Link pins from different entities
Post by: soFPG on May 06, 2018, 12:41:21 pm
I am trying to copy a simple existing CPU inside a microcontroller.
For initial testing purposes I tried to set the program counter to start value 0x000 and hoping for a change at the "instruction-bus", these are my two VHDL-entities involved:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity MDT90P01 is
port (
pc: out std_logic_vector(8 downto 0);
c0: in std_logic;
w_reg_top: in std_logic_vector(3 downto 0);
instruction: in std_logic_vector(10 downto 0)
end MDT90P01;
architecture Behavioral of MDT90P01 is
begin
process(c0)
begin
if(falling_edge(c0)) then
pc <= "000000000";
end if;
end process;
end Behavioral;
library IEEE;
USE IEEE.numeric_std.all;
entity Instruction_Memory is
port (
pc: in std_logic_vector(8 downto 0);
instruction: out std_logic_vector(10 downto 0);
c0: in std_logic
end Instruction_Memory;
architecture Behavioral of Instruction_Memory is
type ROM_type is array (0 to 511) of std_logic_vector(10 downto 0);
constant rom_data: ROM_type:= (
"10010000110",
"10010000110",
(others=>'0')
begin
process(c0)
begin
if(rising_edge(c0)) then
instruction <= rom_data(to_integer(unsigned(pc)));
end if;
end process;
end Behavioral;
But ModelSim-Altera only shows me this, I expected "instruction" to be "10010000110" but it isn't - why?
Title: Re: VHDL - Link pins from different entities
Post by: rstofer on May 06, 2018, 02:01:59 pm
I don't see a 'top' module where you tie the signals together.  Usually this module will just define the various signals and connect them between lower level entities.  You may have such a module and didn't post it.
'pc'' is declared as an output in MDT90P01 and as an input in InstructionMemory but there doesn't seem to be anything tying the ports together.
Post by: soFPG on May 06, 2018, 02:10:51 pm
MDT90P01 is the Top-Level Entity. I am new to VHDL and unaware of that different entities need to be tied together besides equal port names.
I added this:
signal pc_int : unsigned(8 downto 0);
begin
instr_inst: entity MDT90P01.Instruction_Memory
port map(pc => pc, instruction <= instruction);
process(c0)
begin
pc <= pc_int;
pc_int <= pc_int + 1;
end if;
end process;
end Behavioral;
but I get:
Error (10594): VHDL Selected Name error at MDT90P01.vhd(24): object "Instruction_Memory" isn't declared in scope "MDT90P01"
Post by: rstofer on May 06, 2018, 05:41:57 pm
I know I'm going to screw this up...
Assuming your entities are in separate files in your workspace:
library stuff...
entity myproject is
Port (
  clk : in std_logic;
end myproject;
architecture Behavioral of my project is
signal pc : std_logic_vector(8 downto 0);
signal c0 : std_logic;
signal instruction: std_logic_vector(10 downto 0);
signal w_reg_top: std_logic_vector(3 downto 0) := (others => '0');
begin
c0 <= clk; -- for example
inst_PC: entity work.MDT90P01 Port Map (
  pc => pc, -- hook up the wires
  c0 => c0,
  w_reg_top => w_reg_top,
  instruction => instruction
inst_InstMemory : entity work.Instruction_Memory Port Map (
end Behavioral;
Something like that...
ETA:  I had left out a couple of details...
