Author Topic: Video Amplification/splitter from the internet  (Read 5680 times)
Offline Halford
« on: December 24, 2015, 07:57:37 pm »
Hi everyone and Merry Christmas,
I wanted to build a small video splitter and saw online that I have to do an amplification to keep the video quality.
I found this design(1) that used components that I already have and I made a schematic(2) and a board(3)
end of story, I received the board, soldered everything, no video is coming out at the end. Do you see any error? thanks
images updated
« Last Edit: December 24, 2015, 08:44:13 pm by Halford »
Offline bktemp
Re: Video Amplification/splitter from the internet
« Reply #1 on: December 24, 2015, 08:15:01 pm »
There is no connection between R2/R3 and Q1, so Q1 gets no bias voltage.
Offline Aodhan145
« Reply #2 on: December 24, 2015, 08:16:54 pm »
Be more careful when laying the schematic out. You do not need junctions on the pins of all the components. Only place junctions where you need them when 3 or more wires join.
Offline Halford
« Reply #3 on: December 24, 2015, 08:36:12 pm »
Sorry, I uploaded the wrong eagle images.
there is a junction indeed there, here they are:
Offline lincoln
« Reply #4 on: December 25, 2015, 03:46:42 am »
ok, but looking at the layout, R3 and R5 don't go any where....
Online PA0PBZ
« Reply #5 on: December 25, 2015, 11:21:54 am »
None of the grounds go anywhere, it's like it is following the schematics a bit too literally...  :o
Offline Halford
« Reply #6 on: December 25, 2015, 04:12:15 pm »
Well... I'm following it litteraly as I'm a real noob :) ... Got patient and will to explain or tell me where to look to understand it? Thanks anyway
« Last Edit: December 25, 2015, 04:14:19 pm by Halford »
Offline LukeW
« Reply #7 on: December 25, 2015, 04:33:29 pm »
Could you post photos of the physical board you've constructed?
I assume there's actually a ground pour connected to all the ground pins.
Online PA0PBZ
« Reply #8 on: December 25, 2015, 07:16:07 pm »
Where would it be, on the third layer?
Online PA0PBZ
« Reply #9 on: December 25, 2015, 07:17:03 pm »
All the points marked GND should be connected together.
(That is why they all have the same name)
Offline Halford
« Reply #10 on: December 25, 2015, 07:19:43 pm »
all ground are connected.
here is a ratsnest from eagle, and the top and lower image from OSHpark... I was so sure it would work, that I made it print as final online. (probably better then a picture of the circuit)
Thanks for looking
« Last Edit: December 25, 2015, 07:21:54 pm by Halford »
Offline Halford
« Reply #11 on: December 25, 2015, 07:26:08 pm »
I think I found my issue.. bad layout... I feel so idiot.
the 12V input has his gnd not connected to the rest.... I guess this would sabotage the whole circuit.. I feel so stupid.
Online PA0PBZ
« Reply #12 on: December 25, 2015, 07:27:58 pm »
Alright, that looks promising!
Can you measure the DC voltages on the transistors pins and post them?
Offline lincoln
« Reply #13 on: December 25, 2015, 07:44:39 pm »
Its quite all right, nothing a bit of bodge wire will not fix!  :-+
Online PA0PBZ
« Reply #14 on: December 25, 2015, 07:49:02 pm »
Ah yes, floating fills... Been there, done that. Heat your iron and let us know  :)
Offline LukeW
« Reply #15 on: December 26, 2015, 09:29:51 am »
Did you run an ERC?
Offline Halford
« Reply #16 on: December 26, 2015, 01:05:35 pm »
Thanks guys!
It works perfectly!
Thank you for taking the time to look after my post!
Have a great day!
Hal.
