Author Topic: current source, large voltage over load  (Read 5429 times)
Offline chromeTopic starter
« on: May 19, 2012, 08:48:18 pm »
So I need a current source for 200mA but the load needs to go to about 45V(max).
I tried with a transistor  (where the circle is) and that works great up to a certain load voltage but then it can't keep up because of the opamp only having +12V (or +15V) power, so is there anything else I can use for this?
Maybe some sort of Darlington pair or something that feeds of the +50V ?
Offline vxp036000
Re: current source, large voltage over load
« Reply #1 on: May 19, 2012, 08:55:40 pm »
I would try using a common base amplifier after the op amp to increase the voltage swing going to your transistor.
Offline jimmc
« Reply #2 on: May 19, 2012, 09:45:17 pm »
If the load cannot be connected to the 50v rail then either refer everything to the 50v rail (gives earthed load) or use CB stage to level shift Op-Amp output. i.e.
Both use PNP output transistor.
Of course if the load can be connected to the 50v rail then connect other side of load to the collector in your diagram and connect the emitter direct to the 10 ohm resistor.
Watch the dissipation in the output transistor.
Jim
« Last Edit: May 19, 2012, 09:51:34 pm by jimmc »
Online ejeffrey
« Reply #3 on: May 19, 2012, 10:14:10 pm »
All good solutions.  Converting to a current sink is the simplest, but the other options are fine as well.
An expensive but simple solution is to use a high voltage opamp.  If the power rating isn't high enough you can buffer it with an emitter follower.
You could also look at power regulators instead of opamps.  For instance, I think there is a high voltage version of the LM317.  If that has a high enough voltage rating you could use it configured as a constant current source.  This is only convenient if you want a fixed current.  There may be other more modern regulators that would be suitable although high voltage ICs are not that common.
Offline vxp036000
« Reply #4 on: May 19, 2012, 10:33:02 pm »
Actually this is probably the best way to go, using a current sink.  I didn't even think about that :P
« Reply #5 on: May 20, 2012, 11:37:58 am »
The load can be connected to 50V if that makes it easier.
Offline electroguy
« Reply #6 on: May 20, 2012, 02:01:49 pm »
that would make it much easier. in that case, you should be able to use most transistors/mosfets capable of handling the power dissipation and it should work. Doing it the way you had pictured originally is harder.
There are 10 types of people that understand binary, those that do and those that don't!
« Reply #7 on: May 20, 2012, 05:55:55 pm »
Oh man why didn't I think of that, I do that all the time (on/off though).
Offline electroguy
« Reply #8 on: May 21, 2012, 08:52:53 am »
hehe me too!
the other advantage is you can also use nearly any op amp, and can use a much lower voltage to power it, say only 5v. There is no need to get a HV op amp or power it with a voltage as high as your input voltage, etc...
search the forum for "constant current" and you will find a few other threads with similar circuits (and some pitfalls/improvements)
Offline Rufus
« Reply #9 on: May 21, 2012, 09:17:50 am »
An LM317 and one resistor will do that.
It will add about 4v to your supply requirement.
The standard version will stand 40v the HV version 60v.
