Electronics => Beginners => Topic started by: Hogwild on September 30, 2022, 02:38:10 am
Title: Videos on how to open tricky device cases/enclosures
Post by: Hogwild on September 30, 2022, 02:38:10 am
Hi:
I don't think I'm the only one that has come across enclosures/cases that are tricky to open. You know, like the ones with the tabs that interlock with another part of the case. Sometimes, I can open those things and other times I may break a portion of the plastic enclosure or tabs. I find the smaller cases especially hard to open without breaking anything.
Can anyone suggest a Youtube video or two, or at least which search terms I can use to learn how to do this better?
Thanks.
Title: Re: Videos on how to open tricky device cases/enclosures
Post by: CatalinaWOW on September 30, 2022, 04:34:14 am
I find general advise on these pretty useless.  Use a search string like, "opening 'Brand' 'Model Name' and 'Model Number'".  If you are lucky someone has made a video of opening it, and they are not long winded enough that you fall asleep while watching.  If unlucky search on other similar models from the same brand.  You might get some insight into the style that that company uses.  Beyond that obtain strong thin tools and be very, very careful.
Post by: tggzzz on September 30, 2022, 11:01:53 am
It rather depends on the case!
Try using a spudger similar to https://www.amazon.co.uk/ACENIX-Opening-Opener-Spudger-Scraper/dp/B01EQM25JQ (https://www.amazon.co.uk/ACENIX-Opening-Opener-Spudger-Scraper/dp/B01EQM25JQ)
Post by: AndyC_772 on September 30, 2022, 01:52:30 pm
iFixit have some good tutorials. I've also found some of the tools in their 'Pro Tech' tool kit very useful for opening products that probably were never designed to be serviced.
Post by: themadhippy on September 30, 2022, 01:56:08 pm
opening them is easy,the tricky part is opening things in a way that they can be reused.
Post by: AndyBeez on September 30, 2022, 02:21:12 pm
Whether you're using a British spudger or a pry tool, opening enclosures is black art. Even using every plastic or stainless pry tool available, some shut lines will stay shut.
The guys over at https://www.ifixit.com (https://www.ifixit.com) have a few features on tricky enclosures, such as how not to break an iPhone or an iMac screen when ripping off the screen - which is so thoughlessly glued on by Apple's genius design engineers. Ifixit will even sell you the toolsets required.
As for snap together cases, they always snap their clasps when pulled apart. Some enclosures were never meant to be opened for safety; such as power bricks that are sonic or accetone welded. For pry tool read Dremel/file/saw/hammer/house brick.
Of late, this has been my GOTO pry tool. It's sharp on the edges, but not to hard to dint the plastic and, offers good leverage. https://www.ebay.co.uk/itm/283989799200 (https://www.ebay.co.uk/itm/283989799200)
Post by: wraper on September 30, 2022, 02:36:00 pm
You need to search for video instructions specific to particular device. You can learn how to open devices in general but you won't know pitfalls for specific devices. For example there may be some wifi antenna located under the edge of touchscreen which you can easily damage when separating it with spudger. Knowing where exactly hooks are located also is critical for opening without causing damage.
Post by: tggzzz on September 30, 2022, 04:44:24 pm
True :)
The last thing I opened was an obsolete box on a wall. I used a 3lb mallet quite successfully!
Post by: Hogwild on October 01, 2022, 06:23:29 pm
Currently, the device I'm trying to open is a Netgear 5G Router/hotspot. But after 45 mins. of trying, I can only get 3 corners out of four of the case pried up. One corner refuses to budge. I can't find any hidden screws, so...dont' know what to do next.
There are no videos or other resources for disassembling this unit on the Web.
Post by: Infraviolet on October 01, 2022, 09:50:23 pm
Remove all sticky labels, incase any are covering screws. Try running a sharp, but non-conductive, "blade" of some sort right around the crack between casing parts which you've been trying to follow.
Post by: AndyBeez on October 01, 2022, 10:06:41 pm
You can make plastic blades for feeling around cases from cut up plastic bottles. What model of Netgear is this? It's probably held on by a clasp. Wiggle it :)
Post by: Jeff eelcr on October 03, 2022, 09:48:30 pm
Sometimes manufactures use screws and glue, sometimes there are tricks like
a Bose SCR receiver or any Pearlcorder unit.
Maybe they have videos now.
Jeff
Post by: Hogwild on October 05, 2022, 02:07:02 am
You folks were right. There was a hidden screw. It was a b!tch to find. But once I found it, the router opened surprisingly easily.
Thanks for the advice.
