Author Topic: Federal Signal PA300 electronic siren - circuit producing sound  (Read 2644 times)
Offline TallieTopic starter
I recently purchased a Federal Signal PA300 electronic siren "AS IS"(schematic here: http://www.simonthenerd.com/files/policesiren/PA300.pdf). After locating the pin-out, I wired it up to my power supply... and something in the circuit is producing the siren sounds... what is it? Is this normal? No speaker hooked up.
Offline amyk
Re: Federal Signal PA300 electronic siren - circuit producing sound
« Reply #1 on: April 11, 2015, 08:56:15 pm »
I see at least one transformer in the circuit... and they can produce sound like a speaker, although with far less efficiency.
« Reply #2 on: April 12, 2015, 01:55:18 am »
Thanks. Yes. It appears to be the driver transformer. I put a probe on it and it's putting out 1.2Khz. I guess this is normal...
