It's kind of jumpy, the analog needle on the PS moves continuously between the voltages (about a 2 volt range)
* Does the needle move from low to high
- instantaneously?
- in a fraction of a second?
- over a number of seconds?
* Does it move from high to low at the same speed?
* Is is doing this at a regular frequency - or does it change quickly at some times and slower at others?
If you were to plot needle position against time, would it look like a square wave, triangular, sawtooth or sine?
If you could get a video showing several cycles, it would be helpful.
