I've been playing with a design (not mine) for an oscillator for an analog synth. It generates a sawtooth signal and shapes it in different ways (triangular, square, sinusoidal, pulse, etc). The various signals are then connected to the output terminals so they can be patched into the input stages of other modules (filters, mixers, etc).
Some of these signals are taken straight off the output of the output stage op amp, so they will have a nice low impedance for the next module.
However some other signals must have an amplitude that's too large and go through a voltage divider before being exposed. For example the square output goes from the output of a LM301 op amp (configured as a Schmitt Trigger) through a 2K2 / 2K divider, shrinking the output to 2K / (2K + 2K2) = 47%.
The question: wouldn't it be wise to buffer the output of the voltage divider (with an op amp in a voltage follower configuration) to present a nice, low output impedance to the next module? Or, if we didn't care about phase, could we just use an inverting amplifier with say Rf = 51K1 and Rin = 107K (to have a gain of roughly -0.48) in place of the voltage divider to have a much stiffer output (is that the right term?) And if we cared about phase, add another inverting amplifier with a gain of -1 to shift it back in phase?
In other words, if I have a signal swinging between +/-11V and I want to bring it to roughly +/-5V before the next stage, which one should I pick:
a) voltage divider with nothing else, but not the lowest output impedance
b) voltage divider with buffer
c) inverting amplifier with similar gain, but 180deg out of phase
d) inverting amplifier with similar gain, followed by another inverting amplifier with -1 gain.
e) something else?
Sorry about the newbieness of the question, I am just starting to discover the goodness of op amps and there is so much to learn there...
