Author Topic: EE-ATX Standard - Mounting holes  (Read 6545 times)
Offline wishgranterTopic starter
« on: October 12, 2012, 11:09:56 am »
Hello All. Im searching for some documentation regards the EE-ATX Motheboard format. Im buing a Dual XEON board and need litle correction to by EATX/BTX PC case that im can put there... is a SUPERMICRO motheboard size.....
Cannot find ANY hint about mounting holes or something similar that can give me clue where im should make my holes in that case....
EEATX (enhanced extended ATX)   13.68 in (347 mm)   13 in (330 mm)
http://en.wikipedia.org/wiki/ATX
HLA-27b
  • Guest
Re: EE-ATX Standard - Mounting holes
« Reply #1 on: October 12, 2012, 01:14:22 pm »
Same as ATX holes basically.
http://www.formfactors.org/developer%5Cspecs%5Catx2_2.pdf
Check above document page 10.
Holes A G and K are the extra holes used for EATX, detailed dimensions on the following pages.
« Reply #2 on: October 12, 2012, 02:22:29 pm »
Hmm Thanx, but you mention EATX and im need EEATX that have dimension 13.68 in (347 mm)   13 in (330 mm)
the EATX has just 12 in (305 mm)   13 in (330 mm).... OK will try something with it...
Offline petreza
« Reply #3 on: January 31, 2015, 07:17:26 pm »
Hi wishgranter,
Were you able to find any info on the EE-ATX mounting holes standard? Were you able to modify your case to accommodate EE-ATX motherboard?
Thanks!
