Hi
I am new to the forum and a newbie regarding Electronics. I have a question regarding devices that display
the current voltage of a battery whilst being charged. How is that done exactly?
If you connect a voltmeter across the terminals of battery (e.g. a car battery) it would measure approx 12V
depending on the state of charge. That is fine. However, when the battery is connected to a charger (conventional or
solar charger), it charges at a high potential difference e.g. +14V. But how does the charge controller reflect the true
voltage (12-13V) and not the higher voltage whilst being charged?
Does it stop charging for a split second, measure the voltage, display it, and then resume charging or what?
Any info/reference would be appreciated.
I have also heard of the term Battery Driver. Is this similar to a charger except that you could leave it connected or is that
another device?
Regards
Anton
