They are 25V and 35V. But I won't salvage tantalums for a new circuit - you'll never know which abuse they have taken so far and when they eventually might blow up...
A rule of thumb is to operate them at half of the rated voltage and avoid high current transients. If you could tell if the used caps were treated well, you might still be fine to use them...
Cheers
Andreas
