Hello folks, my first post here. I've been lurking the forums for a while, seeking recommendations of digital multimetres, and after a lot of research, I purchased an Aneng AN870 (aka Richmeters RM219 or ZOTEK ZT219). From what I've read, this seems to be one of the best Chinese DMMs available in its price range, and while it's no Fluke or Keysight, it's still a very capable model for a newbie hobbyst like me, maybe even overkill. I received mine today and tested a lot of functions, the first impressions were good and so far it's working fine. However, I still have some questions about basic usage of this DMM:
1. I want to measure resistance, capacitance, test diode polarity bias and continuity, can I just buy these components at an electronics store and test them? Of course I do have electronic equipment such as PC motherboards, but I think it's too much hassle and I don't want go disassembling things just for that. Also, I want to be able to read the specified value on the components.
2. What would be the best way to measure current (in any scale), as I need to place the probes in series with the circuit? The manual tells me to break the circuit path, is that the same as saying I need to measure in series and not parallel? Also, as an ammeter needs very low resistence in order to reduce voltage drop and not affect the current reading much, that also means I also risk damaging the meter if I expose it to large voltages, like 230V mains voltage?
3. According to Lygte-dk review of the AN870 (
https://lygte-info.dk/review/DMMAnengAN870%20UK.html), the 20A input is not very reliable due to heat generated by a current of 20A or higher, and also because of the large drift (5% at 19A), which is higher than the specified tolerance (delta of 0.8%+3) at 19.999A scale. In short, shall I just avoid measuring currents expected to be close to 20A then?
4. Can I use rechargeable Ni-MH AA batteries instead of alkalines to power the DMM, or the lower nominal voltage (1.2V vs 1.5V) will affect the readings? Or the only difference is that the meter will complain about low battery sooner? The Ni-MH batteries are slight longer, but fits the battery holder with some persuasion.
5. is there a "DMM usage for dummies" tutorial here or in another website? Something like a straight to the point guide with pratical measurements, so I can reproduce them myself and fully understand how to use all the functions of a multimetre.
