Author Topic: micsig DP10013 input voltage  (Read 455 times)
Offline thedoc298Topic starter
« on: August 12, 2023, 06:30:34 pm »
The specs for the DP10013 are
Maximum differential test voltage (DC+ACPK-PK): 130V (50X), 1300V (500X) from their site
So does that mean 130 volts Pk to Pk or 65 volts Pk which in turn would be 46 volts rms            so on x50 we have 46 volts rms max
same 1300 PK to PK = 650 Pk or roughly 460 volts rms                                                            so on x500 input is 460 volts rms max
So why don't they state it like that...? Or am I all screwed up..?
Offline m k
Re: micsig DP10013 input voltage
« Reply #1 on: August 24, 2023, 12:48:02 pm »
It's differential so potential difference.
Forget grounds and signal shapes.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
