Hello everybody. I have recently purchased a hot air rework station from frys, but I must know. what would be the best way to preheat the board before attempting to use the hot air gun to remove the BGA device? IR or hot air? I will be doing all work in a small room that is about 8"x10" so heat up of the room itself is an issue as it is a bedroom. i have about a 2.5" x 1.5" space to work with.
Thanks in advance, zerorisers.
