Author Topic: Question about LM317  (Read 2934 times)
Offline bogdan2013Topic starter
  • Always is someone better than you !
« on: April 21, 2013, 09:08:33 pm »
I have an adjustable power supply with LM317 . I can increase the maximum current by putting in parallel more LM317 ?
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Question about LM317
« Reply #1 on: April 21, 2013, 09:13:49 pm »
No, You will need to use one or more parallel transistors, look around the net and you will find a schematic no doubt, or check the datasheet of the LM317 and it may have some hints, this is a common technique to get higher currents from the same regulator particularly when more current that the package could physically handle anyway.
Offline Paul Moir
« Reply #3 on: April 21, 2013, 09:27:59 pm »
That's the idea.
If you're still in the design phase, you might think about something like the ancient LM723, which has a wimpy pass transistor but is pretty easily setup for external ones.  Plus current limiting is simple.
Have a look at:
http://www.thebackshed.com/forum/forum_posts.asp?TID=2249&PN=2&TPN=1
Online mariush
« Reply #4 on: April 21, 2013, 09:33:38 pm »
See  http://www.ti.com/lit/ds/symlink/lm117.pdf  (it's same datasheet for lm117 and lm317)
Typical Applications, page 17-25, you have several designs that all do more current than a single lm317.
« Reply #5 on: April 21, 2013, 09:41:19 pm »
@Paul
Is a old PSU and I want to modify it .
