I have an Onyx Boox e-ink reader that is around seven years old. It has a Wacom's Penabled type display that is sensitive only to, I presume proprietary, stylus and not fingers (I like this behavior since it means you can grab the device any way you want without the pages jumping around). Vast majority of features I use can be accessed with physical keys, but I find the touchscreen very useful for dictionary lookup - just tap the word and the dictionary opens on that entry. Unfortunately, dictionary can not be used without the touchscreen, which leads me to the problem I have.
Recently I noticed that the stylus doesn't work. Initially I suspected the touchscreen was at fault, but further tinkering with it leads me to believe that it's the stylus itself. While I was testing it, I noticed that if I angle the stylus almost parallel to the screen I get response, so I tried using a stylus I got with a Wacom Bamboo drawing tablet. Unfortunately it does not work, however, while I was testing I noticed that if I put both styluses together the Bamboo stylus sort of boosts the Boox one and it works.
The replacement is rather expensive, so before I dish out $40, plus about $40 more for shipping, I decided to have a look inside. I opened the stylus and this is what I found (image in attachment).
I was fiddling with the trim pot, but I get no perceivable change in response throughout my testing. What did produce a dramatic change was the part marked with B. The one in the picture is a replacement I made, since the original jumped from my tweezer into some other dimension. Before I lost it, I got enough testing with the original piece that I am thoroughly confused regarding its purpose. The original piece was made from material visually similar to the long cylinder with coil wrapped around it (marked C). It was ferromagnetic, just like the cylinder and had a dimple to accommodate the small protrusion on the nib (marked A). I tried replicating it as closely as my memory allows me, but I can't replicate the material, so I used a piece of steel. In any case, both the original and my replacement part have the same effect on the stylus. If I place it between the nib and the coil there is a total loss of functionality.
The weird part is that if I remove it and put nothing between (nib and cylinder with coil in direct contact), or a small brass cylinder (I tried similar dimension, and about three times as long), or a piece of paper, or a piece of PVC wire insulation (no wire inside) I get the functionality on the touchscreen. However, the display starts recognizing the stylus at around 10 mm, which is far too far away for usability. The original behavior was recognition only on direct contact (no pressure needed, but not with air gap).
There is one more thing that could be in play, and that is the oval port on the side of the housing. The plug marked E had two thin rods (one is still visible on the plug, the other broke off) leading roughly (or perhaps exactly) towards the two large pads just above the letter D. They were glued with silicone or something similar to the PCB. I tested the silicone looking stuff for conductivity, but I get nothing. No part of the white plastic (which looks like styrene) exhibits any electrical conductivity.
So before I buy a new stylus for much more than I would consider a reasonable price, does anybody have any idea if there is anything I can do?
