Author Topic: want to generate a 50 hz 240 v sine wave from dc 12 volts.  (Read 1819 times)
Offline saipavan
« on: March 05, 2014, 07:28:11 am »
i would like to generate a 240 volts sine wave from 12 volts dc .
i am trying to get the mains voltage from a battery as an emergency power.
(i would like to get a general schematic)
thanks in advance......
Offline lapm
Re: want to generate a 50 hz 240 v sine wave from dc 12 volts.
« Reply #1 on: March 05, 2014, 07:43:58 am »
Well not an easy task your are asking, since not all ac powered devices like it if voltage is not exactly sine wave... I would recomend buy cheap ready made unit. Much safer too if you dont have experience dealing with ac circuits.
In my country i can get small inverter as cheap as 30 - 50 euros, witch in my standards is cheap... Not much point building one unless your doing it to learn or just dont have any other choise...
Emergency power really docent need much, charge your phone, some led lights going... Anything power hungry you are usually better of getting yourself real generator anyways...
Electronics, Linux, Programming, Science... im interested all of it...
Offline saipavan
« Reply #2 on: March 05, 2014, 07:47:47 am »
i want to power my small electronic hobby projects.
i want to learn by designing an inverter(dc to ac converter).
Offline ml-eng
« Reply #3 on: March 05, 2014, 08:05:22 am »
no good project for beginners/hobbyist
Offline saipavan
« Reply #4 on: March 05, 2014, 08:36:09 am »
this isa not only my hobby but also my stream of study.
so i would like to know about it ,how ever complex it may be.....
Offline Codemonkey
« Reply #5 on: March 05, 2014, 09:29:06 am »
So instead of you wanting someone else to do all the work for you and give you a ready made schematic, why not try designing one ?
A few seconds search on google is enough to find multiple designs, but so far it seems you've put in the absolute minimum amount of effort possible by just asking others to do all the work for you without even providing the most basic of requirements (how much power will you expect to run from it etc). Not the right attitude for any future engineer.   |O
Online BravoV
  • +++ ATH1
« Reply #6 on: March 05, 2014, 09:56:12 am »
Find your answer -> HERE and don't be lazy.  :wtf:
Offline saipavan
« Reply #7 on: March 05, 2014, 11:34:57 am »
i am sorry i didnt give enough information .
actually i am not an undergrad now.
 i didnt check in the internet well.i will do that from the next time. :)
