Author Topic: NPN & PNP LTspice  (Read 834 times)
Offline Spitfire1.2Topic starter
  • Country: gr
NPN & PNP LTspice
« on: February 04, 2020, 02:00:44 pm »
Hello!
  I a bit confused with a circuit on LTspice and I need your help if possible.
I tried simulating the following circuit, from my calculation the power on the Led should be around 20mA, but the simulated circuit shows 1.07mA. I tried the same circuit on other simple online simulators like part-sim and falstad and I got the 20mA. Is there something critical that I am missing?  Or is it a design error in LTspice?
Thanks for your time!
921898-0
« Last Edit: February 04, 2020, 02:04:47 pm by Spitfire1.2 »
Offline EEEnthusiast
  • Country: in
  • RF boards, Precision Analog, Carpentry
    • https://www.zscircuits.in/
Re: NPN & PNP LTspice
« Reply #1 on: February 04, 2020, 02:06:30 pm »
Can  you reverse the C & E of Q2 and try again?
Making products for IOT
The following users thanked this post: Wimberleytech
Online rstofer
« Reply #2 on: February 04, 2020, 03:09:17 pm »
What's R5 suppose to represent?
Offline StillTrying
  • Country: Broken Britain
« Reply #3 on: February 04, 2020, 03:34:14 pm »
And what does R3 do, it just looks like a jumble of components to me. :)
  • Country: gr
« Reply #4 on: February 04, 2020, 05:12:31 pm »
R5 is the Led resistor, sorry but I accidentaly moved it. R3 is simulating a load on the NPN. The PNP was reversed  :palm:, i took it for granted that the collector was on the botton. Thanks for the help!
Online Zero999
  • 0999
« Reply #5 on: February 05, 2020, 12:24:58 pm »
What is the circuit supposed to do?
Try varying the supply voltage and see what happens to the LED current.
