Author Topic: Conversion from positive pulse to negative pulse  (Read 1384 times)
Offline dk-001Topic starter
  • Country: tr
« on: June 28, 2020, 04:49:06 am »
For a low current power supply project I need positive and negative square pulses around 200 kHz frequency. Another requirement for the square wave is to have a variable amplitude between 0-10V. Some 555 timers can provide amplitudes close to Vin, so I can vary the Vin for 555 chip and get a variable amplitude. Could you please recommend a method to convert positive pulse to negative pulse (i.e. -10V to 0V) from these or maybe another method?
 I'm planning to use these as input to Cockcroft-Walton multiplier. If possible I would like to avoid using a transformer, and generate voltage (0V-100V or -100V - 0V) on the board by using 5V pr 9V DC input, without a need for negative power rail.
Thank you.
Offline greenpossum
Re: Conversion from positive pulse to negative pulse
« Reply #1 on: June 28, 2020, 04:55:36 am »
By Vin do you mean the supply voltage to the 555? You'll find that the 555 will not function below a certain supply voltage, certainly not 0.
  • Country: tr
« Reply #2 on: June 28, 2020, 05:34:29 am »
Yes, I meant Vin to 555.  I see you point. I don't need to go down to 0V as output if I cannot accomplish the requirements (i.e. I can live with a certain startup value).
Online Jay_Diddy_B
« Reply #3 on: June 28, 2020, 07:10:41 am »
You don't need a -10V pulse to get negative voltages from a Cockcroft-Walton multiplier.
As the voltage goes up, the current goes down. You will only be able to get a few mA at 100V.
Regards,
Jay_Diddy_B
The following users thanked this post: dk-001
Offline David Hess
  • DavidH
« Reply #4 on: June 28, 2020, 03:23:38 pm »
Like Jay_Diddy_B says, a Cockcroft-Walton multiplier can be AC coupled on its input so reversing the diodes will invert the output.
