All these years, I thought I understood something as basic as Ohm's law, but tonight I was disabused of that notion, apparently.
To wit...
I have one of those cheapo 12V automotive "circuit tester" light pen things. I wanted to repurpose it to work with a different voltage by cutting the ground lead and adding in a resistor. Simple stuff, right? So to calculate what resistor to add in at the new nominal voltage, I decided to start by measuring the resistance through the device as it is now (just the bulb, an old incandescent flashlight bulb jobbie). So I grabbed a multimeter and measured it at around 9.5 ohms.
OK. V=IR right? So I divide both sides by R and get I = 12V / 9.5 ohms, = 1.26A. OK, looking good. Then I dial up 12V on my Rigol DP832 bench supply, and clip the light in and see it light up. And the display reads 0.132A. WTF? At first I assumed the power supply had some setting for the units to display and that it was somehow off, but there's that big ole 'A' right there, which seems to leave no room for uncertainty. Then I started thinking my DP832 had a bug or that my multimeter was wrong.
So... grabbed my
real multimeter, an EEVBlog BM786 and measured the resistance again. Same thing - right around 9.5 ohms. Then I decided to do one more "sanity check" and so I wired the multimeter into the circuit in current mode, with the range set to Amps. Powered everything up, and the multimeter and the DP832 both give the same current reading, 0.132A or so.
So two meters confirmed the current draw, and two different meters confirm the resistance of the circuit. And I've read and re-read the
Wikipedia page on Ohm's Law to confirm that Ohm's Law works in units of Volts, Amps, and Ohms. But yet there's a discrepancy of basically a factor of 10 between what I'm measuring and what I'm calculating. I know this is something obvious and trivial that I'm missing, but somehow it's escaping me at the moment (I blame lack of coffee). Can anybody point out what I'm missing in this?
I haven't added any other resistors or anything yet, so what I'm measuring is literally just the circuit tester pen thing with it's bulb and a little bit of wire. I'm defeated here.
