First post, so forgive me if I'm am in the wrong category.
I am doing a project which involves a rotary encoder. A piece of hardware that I haven't worked much with before but I get how it works.
So I am doing some hardware debouncing using a RC filter, schematic is attached. I have changed the filter resistor to 220 ohm and the cap to 0.22 uF as that was the smallest cap I had on hand.
Both pins have been pulled up to 5V by 10k. When I probe over the filter and turn the encoder in either direction, I see pin B going to 0 but pin A barely reaches 4V. I have no idea why this is happening and I cannot for the life of me get it to work. When I probe directly on the encoder output it works perfectly fine, although with the bounces.
Any ideas as to what is happening?
Any ideas?
