Electronics => Beginners => Topic started by: TorqueRanger on January 14, 2014, 02:16:30 pm
Title: Weller WES51
Post by: TorqueRanger on January 14, 2014, 02:16:30 pm
But I wanted to know if there is a way to test the unit without a Iron ???
Are there any problems with these units ???
What tip do you guys use and the reason I am asking I am use to hakko tips..
P.S.
My hakko took a swan dive and broke the whole case and now the only thing left it the circuit boards which still works but looks funky trying to use .... RIP Hakko 939
Jason SR
__________________
Nathan:
Didn't I tell you not to go out, didn't I?
Shilo:
You did, you did...
Nathan:
Didn't I say the world was cruel, didn't I?
Shilo:
You did, you did...
Nathan:
Then tell me how this happened
What I did wrong, tell me why
Can't we just go home, Shi,
And forget this dreadful night?
Title: Re: Weller WES51
Post by: Sigmoid on January 14, 2014, 06:59:06 pm
Well you could 3d print a new case for the hakko. :) I'd hate throwing one out just for the case.
Anyway, the Weller is a good solid device, I grew up on its predecessors, and currently own one. :) I have no idea how I'd test it without an iron. Maybe by getting an iron for it. :)
Post by: Hydrawerk on January 14, 2014, 07:02:55 pm
For that reason I prefer a soldering station made of sheet metal. https://www.eevblog.com/forum/reviews/picked-up-a-damaged-jbc-bd-1ba-station-advice/?action=dlattach;attach=64036;image (https://www.eevblog.com/forum/reviews/picked-up-a-damaged-jbc-bd-1ba-station-advice/?action=dlattach;attach=64036;image)
Post by: lapm on January 14, 2014, 07:03:54 pm
You could try glue it together? There is special glues just for gluing plastics that seems to work well on my experience. Of course it docent look perfect, but should hold just fine.
Post by: SeanB on January 14, 2014, 08:20:01 pm
Broken case is easy to fix using quickset epoxy. Fills gaps, even can fill in for missing pieces.
Post by: TorqueRanger on January 15, 2014, 02:28:02 am
Sorry I don't have a 3D printer...
The case has been repaired many times  before and still falling apart .. So after this time I decided to either buy a used replacement or just buy a new or used station and work on it later when I have the time or sell it  but not sure yet..
Post by: Odysseus on January 15, 2014, 02:47:22 am
I have this model, and love it to death.  The  included ETA (http://www.digikey.com/product-detail/en/ETA/ETA-ND/251746) tip does the trick for almost everything, but i picked up an ETH (http://www.digikey.com/product-detail/en/ETH/ETH-ND/251751) for fine work.
My only complaint is the included sponge.  It tends to accumulate solder in the pores of the sponge, making it hard to clean.  I like these sponges (http://www.digikey.com/product-detail/en/S2626-M-T/EB1005-ND/108252) a lot better. Ten sponges for two bucks!
Post by: amyk on January 15, 2014, 07:22:45 am
Get a Hakko clone, transplant the internals. (Or maybe you can buy the clone case itself from Alibaba/Taobao)
