Hello,
Im trying to do AC analysis of CE amplifier in ltspice. Im getting error "Iteration limit reached" when adding resistor between emitter and ground. Im using bi component for current controlled current source with setting I=I(R1)*100. Why is this failing to simulate? Whats the correct way of doing it?
I attached the schematic.
