Context : I want to buy a new power supply for computer. The two models I am looking at are SeaSonic Focus Gold and Corsair RM750x.
I took a look at reviews (
here and
here) and found that both are using LLC resonant topology for primary side.
The difference is one is half bridge (2 main switchers), the other is full bridge (4 main switchers).
My knowledge about SMPS is limited but from I understand LLC resonant topology (vs simpler design) allow to reduce losses during switching (which should be done when voltage is as close as possible to zero)
I am not directly asking which one I should buy, is corsair better than seasonic, .... or other PC stuff (this forum is about electronic in general not PC hardware).
What I would like to know is if it make a major difference in terms of SMPS stability and performance.
I am a bit surprised the SeaSonic one came with a full bridge as it is (AFAIK) usually used for high power stuff (eg : >2KW).
