The scopemeters have the benefit of the isolated input channels
They are isolated from the rest of the world but not from eachother.
Keep that in mind if you want to measure with 2 channels.
Are you sure on that, the user manual for the 190 series one indicates otherwise and it was the main reason I bought one.
From chapter 8 page 93 of the user manual:
Measuring Using Independently Floating Isolated Inputs
The test tool has independently floating isolated inputs. Each input section (A, B, External Trigger / DMM) has its own signal input and its own reference input. The reference input of each input section is electrically isolated from the reference inputs of the other input sections. The isolated input architecture makes the test tool about as versatile as having three independent instruments. The advantages of having independently floating isolated inputs are:
• It allows simultaneous measurement of independently floating signals.
• Additional safety. Since the commons are not directly connected, the chance of causing short circuit when measuring multiple signals is greatly reduced.
• Additional safety. When measuring in systems with multiple grounds, the ground currents induced are kept to a minimum.
