Author Topic: What are these oscilloscope lightbulbs?  (Read 1939 times)
Offline chucrutTopic starter
  • Country: cl
« on: July 08, 2018, 01:57:44 am »
Hello,
I have an analog oscilloscope with no trace. I was checking the problem and found these two "lighbulbs" near the crt socket. I tested conductivity and they are not electrical conductive inside. They dont have visible filament.
Any ideas what are this "lightbulbs"?. Maybe they are burned because they are not conductive inside?. Maybe they are something more sophisticate?
Many thanks!
Agustin
Online ataradov
    • Personal site
Re: What are these oscilloscope lightbulbs?
« Reply #1 on: July 08, 2018, 02:08:43 am »
They are neon bulbs, they are supposed to be open.
They specifically look like very classical NE-2 bulbs.
They can have multiple uses in a circuit, so you would need to provide more context for where they are located on the board. Most likely they serve as some sort of protection.
« Last Edit: July 08, 2018, 02:12:27 am by ataradov »
Alex
Offline chris_leyson
  • Country: wales
« Reply #2 on: July 08, 2018, 02:13:46 am »
They are neon lamps used to generate a fixed voltage drop in the CRT resistive biasing chain. Typical breakdown voltage might be 60V to 90V depending on the lamp used. Like ataradov said, it all depends how they are used in the circuit but as they are located near the CRT socket they are most likely used for protection.
« Last Edit: July 08, 2018, 02:35:40 am by chris_leyson »
Online David Hess
  • DavidH
« Reply #3 on: July 08, 2018, 02:41:09 am »
In oscilloscope CRT circuits, the neon lamps usually serve as low leakage low capacitance shunt protection to prevent the grid to cathode and heater to cathode voltages from exceeding their maximum limits.  Since the cathode voltage is in the range of -2000 to -3000 volts, this is pretty important.  Often they will flash when power is applied or removed.
Tube based oscilloscopes may use them for the same purpose at various points.
In cheap designs, they might be used as voltage references.
Offline james_s
« Reply #4 on: July 08, 2018, 03:37:34 am »
They were fairly common in CRT computer monitors and TVs too, for the same purpose of shunting HV to prevent arcs in the electron gun from damaging the electronics. They only ever light if an arc takes place.
Offline IconicPCB
« Reply #5 on: July 08, 2018, 04:51:59 am »
Seen in some older designs as indicators that the trace is way off screen.
Offline james_s
« Reply #6 on: July 08, 2018, 04:28:49 pm »
Those wouldn't be on the CRT socket though, they'd be in the front panel.
