Author Topic: What are these solder pins called?  (Read 1677 times)
Offline PeteAU
« on: March 30, 2013, 08:49:24 am »
Hi All,
I'm trying to repair an old board that has some broken pins. They are 0.1" spacing, solder on one side and plugs into a standard DIP socket on the other. They are similar to machined IC socket pins, except a little longer.
Can someone help identify them? What exactly are they called? I tried looking through farnell/futurlec/ebay but can't find a good match.
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: What are these solder pins called?
« Reply #1 on: March 30, 2013, 10:48:05 am »
"turned pin" should get you to the right section
Day Job: Mostly LEDs
Offline digsys
    • DIGSYS
« Reply #2 on: March 30, 2013, 10:59:35 am »
Haven't seen those exact ones, but are these what you mean? One end fits into a machine socket, other end used to solder to a PCB.
« Reply #3 on: March 30, 2013, 12:26:45 pm »
Probably easiest to get standard length ones as above, and stack up using sockets. The sockets also give you a more easily replaceable unit when   they get damaged again.
Offline DaveW
    • WattCircuit
« Reply #4 on: March 30, 2013, 04:05:08 pm »
Just go to the Samtec website and you can specify the exact length you want,
http://www.samtec.com/connectors/standard-board-to-board/100-inch-square-post/terminals.aspx
They make all their connectors to order, so no worries about minimum order quantities or suchlike
