Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
What are those tiny "press to attach" surface mounted PCB connectors called?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: What are those tiny "press to attach" surface mounted PCB connectors called? (Read 1022 times)
SolderSucker
Regular Contributor
Country:
on:
November 11, 2017, 09:34:37 pm »
As the title says - here's an example of one in this video:
https://youtu.be/ETN97XOx4ZY?t=90
Not sure about anyone else but these can be a real pain to clip together as you often can't see that you have them correctly aligned and it's too easy to push down and break one of the tiny retaining clips on each edge, or even one of the pin connections.
Logged
Mickster
Contributor
Country:
Re: What are those tiny "press to attach" surface mounted PCB connectors called?
Reply #1 on:
November 11, 2017, 11:05:45 pm »
FPC connectors?
https://www.google.com/search?q=apple+fpc+connectors&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwiJ-Nje0LfXAhWM7SYKHZ01ABwQsAQINg&biw=1350&bih=618#imgrc=_
Logged
SolderSucker
Regular Contributor
Country:
Reply #2 on:
November 12, 2017, 09:54:59 am »
That's the ones - thanks!
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
