Hello EEV World! - Looking for help to ID these two old components from a COS6100M Oscilloscope.
RESISTOR - 2BJ (H in diamond) 68 Ohm
TRANSISTOR - NEC C2371 L D 3Z
The Problem - The Trace on the scope is blinding. I adjusted the Sub Intensity Adjustment RV1141, and the trace is still insanely bright. I checked the Power Supply Circuit and found that Test Point 5 should be +150V, but is measuring 63.8V. On the power supply circuit I found some heat damage on the Resistor and Transistor in question (both in pic attached). Going to replace these components, haven't had any luck finding them online, any and all help is appreciated for this, my first post.
I also attached the schematic of the Power Supply Circuit. I adjusted RV1211, the 12V adjustment point which influences all the other power circuits. It was at 12.6V, now nominal.
https://archive.org/details/kikusui_COS6100M_E/page/n3/mode/2up
