Hi fellas,
First off.. Please don't laugh. Well ok then if you must
Right, I'm trying my hand for the very first time at reworking. I've got the necessary tools I need (I think.) And I can carry out general solder work pretty well.
To get me started I was having a practise on this old hard drive controller board, things were going very well. I'd managed to remove and replace some tiny resistors/capacitors ok, so I moved on to some DIP and SOIC chips, all went well. So my next attemp was with this PLCC chip, and as you can see it went horribly wrong
It's not a problem becasue as I say I'm just having a go at this for practise.
My procedure was to heat the area in general with the gun, then move in closer and apply more heat around the joints until the chip came free. Once that was done my plan was to clean the solder pads of solder so that I could start again & re-solder the chip back in place, however this is where it went wrong.
I applied some liquid flux and went in with the copper braid and soldering iron. As you can see the top line of pads things went not too bad (for a noob,) however when I tried the bottom row the copper braid stuck to the pads a few times and made a right mess, even ripping out one of the adjacent pads.
What did I do wrong here guys? And could I have some pointers please for future reference as I'm going to keep trying this untill I can do it properly?
Thanks fellas
orb
