With the age of that board that is not likely. Most likely the one on the bottom left is a 455kHz oscillator to do FM modulation on the crystal. the top 2 are to select harmonics of the crystal before they go to the final amplifier and the output tuned circuit, the black coil on the left with the thick silvered wire.
