Author Topic: What do you guys recommend for a cordless soldering iron?  (Read 945 times)
Offline alank2Topic starter
« on: March 25, 2025, 01:51:02 pm »
Offline u666sa
  • Miami, FL
    • Codernov Electronics Repair
Re: What do you guys recommend for a cordless soldering iron?
« Reply #1 on: March 25, 2025, 03:51:35 pm »
https://www.aliexpress.us/item/3256805511909465.html
QianLi
Professional grade stuff. NorthridgeFix uses it, and he even sells it. Be careful though, tips are really tiny. 115 size. If you want larger tips, get something else.
Notebook repairs, HAM radio modifications
youtube.com/@codernovgithub.com/codernov / t.me/c0d3rn0v
The following users thanked this post: alank2
Offline oPossum
Offline Benta
« Reply #3 on: March 25, 2025, 09:35:08 pm »
Portasol Pro Piezo 75.
The following users thanked this post: alank2, u666sa, Ian.M
Offline brucehoult
« Reply #4 on: March 25, 2025, 09:42:50 pm »
Everyone with them seems to love Pinecil.
Offline thm_w
  • Non-expert
« Reply #5 on: March 25, 2025, 10:43:24 pm »
All of these have cords though, I just assume you mean no wall power requirement.
Offline Benta
« Reply #6 on: March 26, 2025, 12:42:39 am »
Yeah. It's got a display and buttons and a MCU and...
Nerds love it.
But for practical use, nothing beats propane. Up to an hour runtime and simple refilling with lighter gas in seconds. No USB charger or something like that needed.
True portability.
The following users thanked this post: fubar.gr
Offline u666sa
  • Miami, FL
« Reply #7 on: March 26, 2025, 12:59:58 am »
[youtube][/youtube]
« Last Edit: March 26, 2025, 01:03:26 am by u666sa »
Offline brucehoult
« Reply #8 on: March 26, 2025, 02:19:27 am »
Nerds love it.
True portability.
Important for some, I guess. OP didn't say, but this is the Beginners board.
I don't do an hour of soldering in a year. On the average day I need it it's probably for ten seconds.
« Last Edit: March 26, 2025, 02:21:06 am by brucehoult »
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #9 on: March 26, 2025, 02:19:55 am »
I've been using the Weller Pyropens for many years and if expense is no concern then these are still my first choice for field work. I have found them extremely effective in tinning larger gauge wires and where larger solder pads or connectors require additional heat, they are also brilliant for working with heatshrink.
They are however prone to a few inherent problems such as ignition failure and if left unused for long periods they can gum up which blocks the butane flow altogether, both of these issues can be easily addressed in the field with a gas lighter in no time and little risk. The diameter at the base of these pens also fits nicely in a spool of solder which can act as a stand.
Offline themadhippy
« Reply #10 on: March 26, 2025, 02:37:07 am »
The lidls gas irons pretty decent for the price,plus they triple up as a blow torch and hot air gun
« Last Edit: March 26, 2025, 02:40:13 am by themadhippy »
Offline ahsrabrifat
  • Country: pk
« Reply #11 on: March 26, 2025, 07:37:18 am »
Yes. It is comfortable to use. Try to purchase from a dependable seller.
Offline Benta
« Reply #12 on: March 26, 2025, 10:42:19 am »
I started out with the Pyropen, but was very disappointed. Bad temperature regulation and wonky ignition.
The Portasol just works.
« Last Edit: March 26, 2025, 09:33:41 pm by Benta »
