Author Topic: Need help identifying a glass diode (hi-res picture, part from circa 1987)  (Read 490 times)
Offline lkundrak
  • Country: cz
I've got no luck finding out how to read markings on pictured part & what would be a replacement part I could buy today.
[attachimg=1]
I'm sure someone with more experience can help?
Thank you!
Lubo
Offline bob91343
Where is this diode?  If this is a repair job, how do you know it's defective?
Offline lkundrak
  • Country: cz
This is almost certainly not a defective diode.
The shot was taken from a part (a vintage logic analyzer probe) that's supposedly working.
Offline bob91343
What probe/analyzer?
Online Andreas
Hello,
the logo seems to be from Unitrode (never knew that they manufactured diodes)
but obviously they sold the diode part to "MicroSemi"
http://www.aufzu.de/semi/unitrode.html
With best regards
Andreas
The following users thanked this post: lkundrak
Offline lkundrak
  • Country: cz
A Tektronix P6442 probe for 1230 analyzer.
Sorry for not having been specific enough.
Offline cortex_m0
I found a photograph of the PCB from that probe: https://w140.com/tekwiki/wiki/P6442
I might guess it is a low-voltage zener, being used there to protect the inputs on the MC74HC04 inverter and the MC74HC240 buffer. But without being able to clearly see the tracks, that's a very rough guess.
However, I see what I think are 10 glass diodes on that board, and if they were protection I might expect 16 (one per bit on the logic analyzer).
Online Andreas
Maybe Tektronix (like many test equipment manufacturers) has its own part numbering scheme.
So without a "repair/maintenance Handbook" identification may be difficult.
with best regards
Andreas
Offline Terry Bites
Given the vintage and the 74HC and 74AC logic, I doubt they are anything special. Probably a switching diode like a IN4148. Trace out the circuit. Is it a bit of M2L?
Offline edavid
Tektronix would order parts marked with their own part numbers.
Tektronix diode part numbers are 152-nnnn-rr where the rr is a revision number.
When the whole thing wouldn't fit, they only printed the important part, the middle 4 digits.
So, the complete part number is 152-0574-00.
Now you can go to TekWiki and look in the transistor and diode catalog: https://w140.com/tekwiki/wiki/Common_Design_Parts_Catalogs
On page 8-7, the spec is given as 120V, 150mA.
One possible replacement would be 1N458A.
The following users thanked this post: Andreas, lkundrak
