Author Topic: LTPoE++ MOSFET Selection (Ideal Diode Bridge)  (Read 756 times)
Offline KKlouzalTopic starter
« on: May 13, 2018, 08:34:58 am »
Hello, I'm trying to select an appropriate MOSFET to use as an Ideal Diode Bridge for my LTPoE++ application.
I need to support the maximum spec for LTPOE++ (90 watts).
I'm using a Linear Technology LT4321 as the driver for my Ideal Diode Bridge.
http://www.analog.com/media/en/technical-documentation/data-sheets/4321f.pdf
To save space on the PCB and reduce complexity these Quad N-Channel MOSFETs look very attractive.
https://www.digikey.com/en/product-highlight/f/fairchild-semi/greenbridge-series-of-high-efficiency-bridge-rectifiers
However i'm a beginner in the world of electrical engineering and I'm not quite sure if I can use these H-Bridge type fets for this application or not.
I was also able to find this single mosfet from Nexperia but they aren't in stock
https://assets.nexperia.com/documents/data-sheet/PSMN075-100MSE.pdf
and I would like to use a single chip to save space and reduce complexity.
The FDMQ8403 seems to be the best choice from what I can find, I'm just not sure about the H-Bridge, if anyone can clarify it would be really helpful.
https://www.fairchildsemi.com/datasheets/FD/FDMQ8403.pdf
I may just have to go with 8x of the TI CSD19538Q3A
http://www.ti.com/lit/ds/symlink/csd19538q3a.pdf
Any recommendations would be greatly appreciated.
Thank very much you for your time!
« Last Edit: May 13, 2018, 10:09:35 am by KKlouzal »
