Hi, im making test to control a 100V signal (That goes to another transistor to control a Relay) with an SCR and the SCR signal is 3.3V from a microcontroller.
The problem is that the output voltage in the SCR is only 3.3V, same as the gate. The SCR acts ON and OFF as it should but the voltage is not 100V, yes, the Anode is connected to 100V (DC, since comes from batteries in series). And the output is the Cathode.
Should I be getting 100V in the cathode or im mistaken? Any suggestions?
The SCR im using is the C106B.
Im controling the SCR using a PUSH-PULL NPN-PNP config at the gate.
