Typically this concept is applied to VLSI or FPGA design as it relates to different sections of a chip that are supplied with power on separate rails. A mixed-signal design, for instance, may use a +15V to -15V dual-rail voltage domain for its op-amps, while also having a 3.3V domain for digital logic. Bus adapters or voltage converters are used to interface signals between domains.
