The parallel combination of two resistors is their product over their sum. So, two 100 Ohm resistors in parallel => (100 * 100) / (100 + 100) or 10,000 / 200 or 50 Ohms.
Here is a crib sheet:
http://www.calvin.edu/~svleest/circuitExamples/equRes/Look at the 4th sketch, what a mess! Let's start...
Add up the 3 series resistors on the right edge (3+6+9) = 18 Ohms. Now calculate that 18 Ohms in parallel with the 5 Ohm resistor (5*18)/(5+18) and let's just call it 3.9 Ohms.
Now combine that 3.9 Ohms wth the 2 & 8 Ohm resistors to get 13.9 Ohms. Calculate the 13.9 Ohms in parallel with the 4 Ohm resistor and get 3.1 Ohms
Finally, combine the 3.1 Ohms with 7 & 1 Ohm resistor to get 11.1 Ohms total equivalent resistance.
That about covers it!
Arithmetic errors are all mine...
