Thanks Jeroen
I came across with the design you posted. I understand we dont have to use common mode choke but I have to use it for our company standard purpopse. The schematic which I posted if I want to use same component then what can be the configuration should I follow. Because thre is too much information is available and so I am little confused.
And how do I connect VBUS to FTDI?
And how does the VCCIO and 3V3OUT of FDI is connected?
I have attached the new schematic,I hope this will give you my side.
