Author Topic: What is a Child Board?  (Read 3814 times)
Offline electroluxTopic starter
    • Photography
« on: May 25, 2014, 10:54:22 am »
What is a Child Board :-//?
The funniest thing about this signature is that by the time you realize it doesn't say anything its too late to stop reading it.
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: What is a Child Board?
« Reply #1 on: May 25, 2014, 10:59:01 am »
It's when you have forum boards categorised  so say the MCU section was categorised, each section would be a "child board" of the main section
Online amyk
« Reply #2 on: May 25, 2014, 11:56:54 am »
Makes sense a moderator would reply about boards in a forum... but I think the OP might've been referring to PCBs, in which case a child board is a smaller board that's plugged into a motherboard.
Offline Simon
  • Global Moderator
« Reply #3 on: May 25, 2014, 11:58:05 am »
err, motherboard - daughter board that's how I've always heared them refereed to as
Offline Rerouter
« Reply #4 on: May 25, 2014, 12:13:49 pm »
can even be used to refer to a mod board, where the designers removed an IC and fitted a pcb on legs in place to modify the function, i've seen this many times with older digital panel meters,
Offline Yago
« Reply #5 on: May 25, 2014, 02:04:43 pm »
A GrandMother Board? :p
Offline Simon
  • Global Moderator
« Reply #6 on: May 25, 2014, 02:16:09 pm »
watchit we'll be accused of sexism next....
Offline Richard Crowley
  • KJ7YLK
« Reply #7 on: May 25, 2014, 02:37:35 pm »
It is the Politically Correctâ„¢ term for "daughter-board"*.
* I only use the term "daughter-board" for illustrative purposes. No SEXISM should be inferred from that usage.
Offline Simon
  • Global Moderator
« Reply #8 on: May 25, 2014, 02:39:42 pm »
Yes i was the first one to mention daughter-board, only joking
