Author Topic: Help finding a jellybean optocoupler for PWM  (Read 666 times)
Offline rubemjrxTopic starter
  • Country: br
« on: January 20, 2022, 11:38:02 am »
Hello, I need a relatively low cost and easily available optocoupler for controlling a half bridge driver (IR2104) with PWM. This is for driving a DC motor, so I need it to be able to switch at least 5kHz with reasonable precision (10 bits maybe?), ideally a higher frequency but not really so much (using IGBTs).
I have tried looking at what local electronic stores have in stock, but haven't found anything enlightening.
Thanks!
Online Zero999
  • 0999
Re: Help finding a jellybean optocoupler for PWM
« Reply #1 on: January 20, 2022, 02:31:32 pm »
The IR2104 is obsolete.
I recommend an isolated gate driver. The ADuM5230 is nice. A contractor designed a solenoid driver using it. A big advantage is it contains a built-in isolated power supply. A complimentary pair of emitter followers can be added to the outputs to give a higher peak output current.
https://www.analog.com/media/en/technical-documentation/data-sheets/ADuM5230.pdf
