Author Topic: What is the functional difference between parallel flash and parallel EEPROM?  (Read 707 times)
Offline alank2Topic starter
Offline langwadt
usually if you need to change a byte in flash you need to erase a whole sector, in eeprom you can change a single byte
Offline jackthomson41
Flash memory, also known as flash storage, is a type of nonvolatile memory that erases data in units called blocks and rewrites data at the byte level. Normally used for storing code.
EEPROM is also a non-volatile memory, data will remain intact even it's powered off. Normally routine data is saved in EEPROM. Btw I am talking about Microcontrollers.
« Last Edit: March 10, 2021, 01:06:02 am by jackthomson41 »
Offline MosherIV
Another difference is the memory size of flash and eeprom.
Flash will generally be larger than eeprom.
Fash is available in Mega Bytes (MB)
Eeprom is available in KiloBytes (KB)
« Last Edit: November 01, 2019, 07:45:21 am by MosherIV »
