I could barely get anything from one end of my apartment (a sprawling 1 bedroom estate) to the other using powerline networking, thanks to the living room (where the modem is) and bedroom (where my desk is) being on different phases.
But more tellingly, even a test with the two things plugged into the same wall outlet resulted in performance far below the claims. If they can’t deliver anything close to their promised bandwidth over a distance of under 1 meter, I declare it crap. And having since learned that they are EMI nightmares, I actually tend to agree that they should probably have never been allowed.
I then replaced the (useless to me) analog phone wire with CAT 6 or 7, replaced the wall plates with RJ-45 jacks in keystone plates, and ran the remaining patch cable under the baseboards and around door frames using that extra flat CAT 5 cable, and now I have flawless gigabit between the rooms, more than enough for my 600Mbps internet.
Amusingly, I actually do need two Wi-Fi routers for my “estate” because its layout puts two heavy masonry walls, plus all the kitchen appliances, in between the living room and bedroom, enough to severely impact Wi-Fi, especially if the microwave oven is on, since it’s right in the path. So each wing of my apartment has its own access point.
