Silicon is a semi-conductor, which means that it conducts significantly less then "the average metal", but much more then insulators.
https://en.wikipedia.org/wiki/SiliconDoping silicon is typically in the single digit ppm range or less, and this changes very little to it's overall conductivity.
It is only the interaction between the N and P boundary layer that strange things happen.
There is also a similar boundary layer between a metal and doped silicon, that is called a skottky diode.
But the bulk material itself is just slightly resistive regardless of the small amount of doping.
** Edit **
Oops, I: )(*&^%$#@!
As written below...
A "clean" semi conductor, conducts a bit, and adding doping adds charge carriers, and thus indeed increases conductivity and decreases resistance.
So I agree with the kind peaple below and I wrote down a bit of a brain fart here earlier.
I'm sorry for that.
