Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
What is this conector type?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: What is this conector type? (Read 727 times)
001
Super Contributor
Country:
on:
August 22, 2019, 01:14:04 pm »
Hi
I`m gonna buy LCD with ribbon wire
What type connector on PCB I need?
Logged
mariush
Super Contributor
Country:
Re: What is this conector type?
Reply #1 on:
August 22, 2019, 01:18:43 pm »
Flat flex connectors ... figure out number of traces and pitch (spacing between the wires) and thickness of ribbon cable :
https://www.digikey.com/products/en/connectors-interconnects/ffc-fpc-flat-flexible-connectors/399
The displays don't have the same ribbon cable... the datasheet would normally say or you can determine from drawings.
Logged
ledtester
Super Contributor
Country:
Reply #2 on:
August 22, 2019, 01:23:08 pm »
Have a look at:
https://www.aliexpress.com/item/32982483720.html
and:
https://www.aliexpress.com/item/32858205410.html
Make sure you get the right pitch.
Logged
Ysjoelfir
Frequent Contributor
Country:
Reply #3 on:
August 26, 2019, 08:58:59 am »
How about looking into the datasheet for the Display you intend to buy? Most probably they tell you exactly which mating connector should be used.
Logged
Greetings, Kai \ Ysjoelfir
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
