Author Topic: What is this conector type?  (Read 832 times)
Offline 001Topic starter
  • Country: aq
« on: August 22, 2019, 01:14:04 pm »
Hi
I`m gonna buy LCD with ribbon wire
What type connector on PCB I need?
Offline mariush
Re: What is this conector type?
« Reply #1 on: August 22, 2019, 01:18:43 pm »
Flat flex connectors ... figure out number of traces and pitch (spacing between the wires) and thickness of ribbon cable : https://www.digikey.com/products/en/connectors-interconnects/ffc-fpc-flat-flexible-connectors/399
The displays don't have the same ribbon cable... the datasheet would normally say or you can determine from drawings.
Online ledtester
« Reply #2 on: August 22, 2019, 01:23:08 pm »
Offline Ysjoelfir
« Reply #3 on: August 26, 2019, 08:58:59 am »
How about looking into the datasheet for the Display you intend to buy? Most probably they tell you exactly which mating connector should be used.
Greetings, Kai \ Ysjoelfir
